-   -   b&m 250 blower carb plate question. (https://www.offshoreonly.com/forums/general-q/288004-b-m-250-blower-carb-plate-question.html)
mustangmark 11-20-2012 07:13 PM
To the best of my knowledge b&m never made a top plate for their 250 blower for a Holley 4500 dominator. I am currently using an adaptor on my set up but really need the 3/4" that the adaptor is taking away for flame arrestor clearance.
Can anyone tell me if The Blower Shop's dominator/4500 top plate that they offer with their billet 250 blower will interchange or bolt onto the b&m housing?
Rookie 11-20-2012 07:24 PM
1 Attachment(s)
I have a dominator on mine. Actually I believe it will accommodate a 4150 or 4500.
I also have Dual 4150 plates.
supermx96 11-20-2012 08:50 PM
Your single carb plate must be modified with some machine work ???
I never see a non modified single top plate for 4500 carb when i have try to find one.
I run mine with 4500 to 4150 adaptor last summer, I will try to run with twin carb setup for the next season.
mustangmark 11-21-2012 03:14 AM
I used an adaptor plate on mine but in order to keep the fuel from deadheading against the edges of the adaptor and top plate I had to remove and blend a lot of material from both. It came out ok but in the process reduced the width of the gasket for the top plate to about 1/2 it's original size along either side of the plenum. It works fine but I'm still having a height issue. Did anyone else remove material and blend the sides of their adaptor and top plate like I did?
MILD THUNDER 11-21-2012 06:38 AM
Mine had the B&M adapter, modified for the 4500 carb. Didnt use a actual 4500 to 4150 adapter, just the B&M plate was machined.
I have two fiberglass hatch inserts that I took out of my setup. They give about 2.5-3" additional clearance for a single round flame arrestor. For sale if you need them.
Rookie 11-21-2012 07:36 AM
How concerned is everyone about running a single carb on a 250? The bottom of this thread the poster has some #'s I am/would be concerned about.
http://www.hotrodders.com/forum/b-m-blower-189957.html
MILD THUNDER 11-21-2012 08:22 AM
My results concurred with that thread you posted rookie. Rear cylinders run fat, fronts lean. Dual carbs much better.
mustangmark 11-21-2012 08:39 AM
I appreciate the offer M/T. I've already got a arrow scoop glassed onto my hatch. I did a little digging and found a guy that is willing to make a billit top plate for me. I'm not sure I'm going to go that direction or not yet. I need to find out what its going to set me back. I read the link in the other post and have heard that there can be fuel distribution issues using a single carb on the 250 blower. I currently run the top plate that mounts the carb in the center instead of forward and a Nickerson stage 5 dominator. So far...no issues and Ive consistently spun the motor to 6200rpm. I just picked up a 26p bravo1 to drop the rpm a little. The current prop is a 24p bravo1.
eddie 11-21-2012 08:40 AM
Here are the instructions for the 250 if that helps at all: https://dl.dropbox.com/u/42339868/25...directions.pdf
