28 Sleek craft (porposing)
I have a 1989 28'Sleek approx 5000lbs wet. I have just rebuilt motor approx 500HP. I have tried a 26p bravo 1 and a 24p hydromotive. The boat seems to porpoise when I trim it all the way up to get top speed. Approx 63MPH 113 degree day. I had a 3 blade 21p mirage prior and don't remember it porpoising as bad before. Second since the rebuild and repaint I have notice the boat rides crooked to the left side and have to tab it straight. I am not sure if there is a weight dist. problem and if there is how much would it take.The props are all right hand rot.
Any thoughts would be most helpful. |
If these are Bravo drives why are you not counter rotating them? also the Bravo 1 props are transom lift props. If you didn't raise your x dimension and you didn't have a problem with blowing out on take off ---- go back to the 3 blade mirage + prop it will give you more bow lift than the older standard mirage.
powerboat,
I believe all 28 sleeks coming out of the factory today have left hand rotating 3 blade props. You might want to call sleek craft and disscuss this problem with them. ask for jack Lyle. 602-954-0725 I hope this helps, jdelo |
Thanks that helped out a lot Jack said they are running 24p bravo 1 left hand rotating to level the boat out.
| All times are GMT -5. The time now is 12:00 AM. |
