Originally Posted by MILD THUNDER
(Post 3825428)
Like it was said, too many variables, but sure sounds like a nice parts list. Callies cranks, carrillo rods, Dart heads, jesel, tall deck blocks, etc etc. I can see those engines with a roots 10-71 making 900+ with maybe 7-8lbs of boost.
Don't know jack about Vortech blowers, but sure looks like they are overdriven just a little! 750HP should be easy on low boost mode with that setup. |
Originally Posted by 4bus
(Post 3826080)
Dude, that is a cool ride.
Hope to see you in Abay this year |
Originally Posted by articfriends
(Post 3826581)
They are overdriven even more than you think, the internal gear box steps them UP even higher, not sure what ratio Vortech uses but on my Baja I am running Procharger M-3s, the lower crank pulley is about 7.750, the blower pulley is 3.70 and the internal gear box is 4.44-1 UP,the blower on mine turns just about 10 times faster than the motor, at 6000 rpm's the blower is turning 56000 when I do the rough math, Smitty
I asume that your are about maxed out with that unit? I would love to see that boat in action!!!!! |
Originally Posted by abones
(Post 3826741)
Smitty
I asume that your are about maxed out with that unit? I would love to see that boat in action!!!!! I exploded a head unit once a few years ago too so they are NOT indestructable but seem to hold up decent even wicked up! |
Ok, so I still dont know the answer, but bit of an update:
-Turning 17 3/4 31P 4 blade props Took her out on the weekend and GPS'd 80 MPH at 4300 RPM with 13 ppl on board and a FULL (600 litres) tank of fuel! Still had a lot more throttle and more trim too! :) |
| All times are GMT -5. The time now is 10:24 AM. |
