-   -   Amber like material in exhaust (https://www.offshoreonly.com/forums/general-q/288553-amber-like-material-exhaust.html)
Young Performance 12-07-2012 06:04 PM
Originally Posted by mike tkach (Post 3828235)
i also see white stuff around the end of the valve seat,and looks like a lot of rust on the freeze plug,strange since they are brass when they leave mercury.
I think that's a head bolt washer you are seeing.
Eddie
smiklos@sunprint 12-08-2012 08:41 AM
Eddie
I agree
mike tkach 12-08-2012 08:51 AM
Eddie
yes,its to high to be a freeze plug.
EdNewman 12-08-2012 11:09 PM
Yes, that's a head bolt.
TWIN-SPINS 12-09-2012 08:20 AM
could a small amount of reversion,be causing this???
EdNewman 12-09-2012 09:08 AM
Possible, but it is on all 4 sides. And wouldn't it be salt then? I'm still thinking some sort of fuel additive.
brian41 12-09-2012 12:17 PM
Do a bleed down test, my bet is reversion and leaky valves. I have seen this on several 525's with high bleed down numbers, some over 50% with less than 150 hours on them.
EdNewman 12-09-2012 09:22 PM
I finished breaking down the engine. There was some salt residue on the exhaust runners. Maybe it is reversion an just something in the water.
MILD THUNDER 12-09-2012 10:29 PM
PSI check your headers if you haven't done so to rule that out.
EdNewman 12-10-2012 02:44 PM
Have not done yet, but I am now in the tiresome habit of pulling and testing them every winter, even with the new Hardins. So far they have been good, just one pin hole.
