Want to add a on board batt charger
I have 4 batteries on the boat 2 on each side. they are wired in parallel. I only need to recharge the batteries when it is back home in the barn. I am thinking a charger in the 30-40 amp range, My question is can I use a 2 bank charger it seems 4 are hard to come by ..Any suggestions? .. Thanks
i have 3 in mine 2 in parallel & 1 seperate, had a 10 amp 2 bank chrger & when i added the 3rd batt it didnt last a month. called the manufacturer & he told me a 20 amp 2 bank will be fine. so far 3 months & no issues
I would think you would be fine as long as you have them on two separate circuits. Having it on individual batteries doesn't seem to be a major issue.
They are on 2 circuits.. Thanks I will go shopping ..
You might try Amazon.com I picked up a 4 bank 40 amp charger that was pretty reasonable. Its a Genius by Noco. Randy
A pro sport 20 from cabelas works good also, charged 4 batteries for me with no problems
Originally Posted by Scarab29
(Post 3832284)
I went with a mastervolt 3/40 amp, seems hard to find a 2 bank in the higher amps..
| All times are GMT -5. The time now is 03:32 PM. |
