manifold - riser replacement
hello fellas,
I have a 496ho with 85hrs on it. it is used in salt water. My question is, when is it time to change the manifold and/ risers? is there a calendar and time limit like with other components? and should both the manifold and riser be changed or only one of the two? Thanks |
As long as you are flushing them after each use, you should get at least 5-8 years out of them.
| All times are GMT -5. The time now is 10:50 AM. |
