What bearing to run for 489 build >
Old 01-04-2013, 06:43 AM
  #51
Originally Posted by mrfixxall
i have about 60 psi @ 6200,,,25-30 at idle.small oil cooler ..i also run full syn oil and filter..8qt oil pan..i only run about 2-3 miles at that rpm then i cruise at 5 k
Cruise at 5K? That's either a typo, or you have dropped a pro stock engine in there!
Budman II is offline
Old 01-04-2013, 10:10 AM
  #52
Small block.
MILD THUNDER is offline
Old 01-18-2013, 09:19 AM
  #53
Originally Posted by riverrat
Alex you can't fix stupid
Jeff A.
thats true,you are living proof of that,every time you post,you proove your stupidity,the only one that thinks you are funny is you.GO AWAY,nobody likes you or your big mouth.
mike tkach is offline
Old 01-18-2013, 09:37 AM
  #54
Old 01-18-2013, 02:27 PM
  #55
blue thunder's Avatar
When you buy the place and gain the power to tell who can stay & who should go then maybe, you've run enuf guys off the site by your kindergarten antics and there guys who have been on the site longer then you and WAY more knowledgeable that wont post anymore cause all you do is beat up other members opinions if there not the same as yours. Go back to moochin off the Govt
Jeff A.
Dam RR is it happy hour already?
blue thunder is offline
Old 01-18-2013, 07:38 PM
  #56
Jeff A.
as usual,your mouth is running,but nothing you say is factual,put the crack pipe down,anytime you want to see if my engines are junk,bring it on,im sure you are used to embarrassment.you and your buddy are a joke big daddy.
Old 01-18-2013, 10:09 PM
  #57
happy hour:b ong:
Old 01-19-2013, 05:34 PM
  #58
Originally Posted by mike tkach
happy hour:b ong:
All of what he said is not invalid. This place was better back in the early 2000s when the point was always; the fun of offshore high horsepower boating. Whether on an inland lake or out in the real deal. We should try to remember that in our interactions. Most of which on here for my 13yrs have been accretive to my existence.
BT
