-   -   procharger v groove pulleys (https://www.offshoreonly.com/forums/general-q/289565-procharger-v-groove-pulleys.html)
mustangmark 01-02-2013 05:24 PM
Does anybody running a procharger know which 3 v groove pulley needs to be run at the crank for the accessories (p/s, alt and sea pump). Can I use a standard billet pulley or does it need to be procharger specific to fit the procharger drive pulley? Thanks, Mark
ezstriper 01-03-2013 06:55 AM
they made a early kit for the V belts, mine is serpentine sure you would need to get right pulley from procharger...what are you trying to do ? piece together a kit ?
HaxbySpeed 01-03-2013 09:51 PM
5 Attachment(s)
It depends on what accessory brackets you're running, specifically the power steering pump. The Procharger PS bracket pushes the pump forward so you need a different offset for the front crank pulley then on a traditional V-belt set up. The water pump and alternator pulley are the same offset as factory. If you use a stock crank pulley, you need to clearance it a bit and run a spacer to put the SC pulley in the right spot. If you use a billet pulley you don't need to clearance it but, you still need a spacer. Either way, unless you relocate the PS pump you're gonna have to get creative, or just order the correct ProCharger pulley. Any competent dealer can help you out. I dug a couple pulley's outta the basement so you can see the difference. The bolt pattern is the same as it bolts right through on to the balancer.
mustangmark 01-04-2013 12:20 AM
Awesome info.....thank you so much! It's very appreciated!
