-   -   Best cam selection? (https://www.offshoreonly.com/forums/general-q/289637-best-cam-selection.html)
GTOKILLER 01-04-2013 08:23 AM
Best cam selection?
SBC 377 8:1 comp. full roller, cast heads 202/16 valves. With Weiand 177 whats your opinion??
mcollinstn 01-05-2013 01:42 PM
You've only given about 8% of the required information needed to make a cam recommendation.
GTOKILLER 01-05-2013 03:57 PM
Well I'm open to questions, thats why I asked. :angry-smiley-038: what else do you need?
innerrage 01-06-2013 06:08 PM
call BOB MADERA and have him spec a cam for you.
Jeff P31 01-06-2013 10:15 PM
I have had Comp Cam make cam's for me . They were plenty helpful , tell them what you have and what you are after and they will fix you up .
mustangmark 01-06-2013 10:57 PM
Originally Posted by innerrage (Post 3843627)
call bob madera and have him spec a cam for you.
+1
Trash 01-07-2013 12:56 AM
Crower has a set of hyd roller EFI/Blower/NOS cams that work well.
boyomarga 01-07-2013 02:42 AM
Well I'm open to questions, thats why I askedhttp://bestpokersitesreview.com/images/19.gifhttp://bestpokersitesreview.com/images/20.gifhttp://bestpokersitesreview.com/images/21.gifhttp://bestpokersitesreview.com/images/22.gifhttp://bestpokersitesreview.com/images/23.gif
mcollinstn 01-09-2013 05:36 PM
What heads/what cc?
What squish height are you running?
What carb?
What boost do you plan to run?
What would you like your max rpm to be?
What is your expected cruise rpm?
What boat/type/weight?
What type of boating do you do?
Do you plan to pull wakeboards/skiers/tubes? How often?
What octane fuel do you plan to run?
That's a START.
MC
GTOKILLER 01-09-2013 08:55 PM
Thanks for the suggestions I had Comp grind me a couple for my exact use.
abones 01-09-2013 09:42 PM
good Choice what are the specs?
GTOKILLER 01-14-2013 09:53 AM
Ill know in a a couple weeks when I get them back, I dont remember & they are at the builder already. Weiand's are on backorder for 14 days :(
dennyp123 01-18-2013 10:51 PM
Originally Posted by mustangmark (Post 3843800)
+1
+2 Have Bob teach you about cams for your first time around. Then on your next boat when you know alot more, you will still be so happy with what he did the first time that you will call him again.
goebel1 01-18-2013 11:01 PM
Originally Posted by dennyp123 (Post 3851502)
+2 have bob teach you about cams for your first time around. Then on your next boat when you know alot more, you will still be so happy with what he did the first time that you will call him again.
+3
