-   -   how much for these 496 builds? (https://www.offshoreonly.com/forums/general-q/289683-how-much-these-496-builds.html)
mookster 01-04-2013 07:27 PM
in the future i like to buy or build a 496 marine motor. ateco has 496 550hp for $9900.00 454 reconditioned block scat crank. gm heads
http://www.atecoengines.com/enginesdl.php
whites racing has 496 they use dart blocks but use , probe pistons, and alum procomp heads 500hp for $6200.00
http://whiteperformance.com/marine_eng_WIDE.html
or should i just find some good used 454 blocks and build one with 550hp
or are these prices from these shops good deals?
mookster 01-06-2013 12:08 PM
ttt
Black Baja 01-06-2013 08:38 PM
That's pretty high I can get 540 long block. Forged crank JE piston'S upgraded bolts with pan, balancer hydraulic roller. With GM heads 575 hp. $7200 with Dart block $7300 Boetie block. Everything brand new except 088 heads that have iconel valves. Better get a lot more for $9900... Actually I take the little high statement back that's just rapping someone. You can build a motor with practically the best of everything for 12-13 grand.
Donskihp 01-06-2013 09:00 PM
Dart doesn't make a 496 base block that I can see. Is it a 502 bore and stroke or something? The 496 in my knowledge is a block of its own not interchangeable with anything else.
picklenjim 01-06-2013 09:48 PM
Dart 454, 4.25" bore with a 4.380" stroke crank.
ezstriper 01-08-2013 09:12 AM
I thought most 496's were 454+.060 w/4.25 stroke ??
picklenjim 01-08-2013 11:36 AM
Homemade ones usually are when made from used 454 blocks. New from merc their not. I wouldn't think they would take a new Dart block and punch it out .060" out of the box. Then again I never seen anything on that link stating they used Dart blocks, maybe he called them or maybe they use used Dart blocks!
http://brucebullockmarine.com/mercur...ag_375_hp.html
