gaskets
what it the better choice felpro or cometic
heads and exhaust, valuve covers application |
Originally Posted by cig20
(Post 3851579)
heads and exhaust, valuve covers application For everything else, I like felpro and victor reinz. |
best place to buy
and thanks for all help |
Call Bob at performance gaskets in Germantown.
262-677-4690 |
Originally Posted by MILD THUNDER
(Post 3851604)
262-677-4690 |
i like the felpro mls head gasgets over the cometic,s,you dont need a mls head gasget untill you go over 1000 hp,the felpro marine is a stout gasget,and about 50% the cost of mls.
Never had oil dripping from the rivets of the FelPro MLS like the Cometics.
Originally Posted by GPM
(Post 3851628)
(Post 3851604)
262-677-4690 |
I think cometic was the originator of the MLS style gaskets many years ago on import production cars.
The nice thing about cometic is the wide array of sizes. From thickness to bore sizes. Fel pro works great in most applications, and they put a jazzy black sticky coating on them. But if you're into tweaking quench heights, and tight bore seals, cometic has more to offer imo. For example, if you have a std bore 502 (4.470), Fel pro's closest is 4.580 bore. Cometic has a 4.500. If you had a std bore 454 (4.250) Fel pro has a 4.370, cometic offers a 4.320. Im not a engine builder, but was told by one ideally you want to keep the gasket ring tight as possible to the bore. Plus cometic will make any gasket spec'd to your likings for you. When I installed my cometics I gave them a couple coats of "copper Kote" spray. Let it tack up and installed them. No leaks. Proper RA finish is important and you cant get any specs of dirt between the layers ! |
Originally Posted by riverrat
(Post 3851709)
Cometic does offer a 4.250 as well
Jeff A. Cometic Manufacturer's Part Number:C5835-040 Part Type:Head Gaskets Product Line:Cometic Head Gaskets Part Number:CGT-C5835-040 Bore (in):4.250 in. |
Cometic custom made thickness, no leaks 5 years now. As MILD said made to your specs. I couldn't be more pleased.
| All times are GMT -5. The time now is 08:39 AM. |
