How to test manifolds
Hey guys I have a pair of some weird manifolds which I suspect they are leaking because my oil keeps gettin water in it, I changed the headgaskets heads were sent to machine shop to be shaved, and am still getting water in oil these manifolds seem
To have been home made http://i21.photobucket.com/albums/b2...x/IMG_1106.jpg |
Friend throw those junk pipes as far as you can . I hope you didn't ruin a good engine with those . You can find good used exhaust manifolds in the swap section cheap . Who ever sold you those should be nutted . :angry-smiley-038:
I know I gotta throw them away for sure but I don't know if I should buy new ones and then the motor still be getting water in the oil
Originally Posted by kakarot
(Post 3851699)
Originally Posted by riverrat
(Post 3851706)
May want to check those heads for cracks, or if you did'nt use Teflon on the threads for the water passages . those pipes from that 1 pic appear to be DRY so no water would be in them
Jeff A. |
The pipes are not dry they are wet also when I took them off from the engine they had water indeed the exhaust part..
(Post 3851726)
After doing the heads I only took it out on the water for ashore period of time you think it could of damaged the valves and guides?
(Post 3851749)
So I guess it's the manifolds leaking then..
Boy! those are old Stainless Marine I think. I have a sm block set on my wall from 74 when SM was in a garage. Junk em.
I just took one of them off and there was some water in the exhaust part, and 3
Out of the 4 exhaust ports on the head were Wet.. |
(Post 3851864)
I will do that tomorrow and ill remove the other manifold as well ill keep you guys posted thanks a lot
Just
Took The other manifold off and there is also water inside the manifold and the exhaust Ports on the head are wet |
would be better to start the motor, even with no manifolds at all. run about 30 seconds. will blow out all the water (on the top of pistons) and the heat will dry out the little left. drain and replace the oil also. if water in oil, might take 5 oil changes to get it all out...another possibility. this is a big block. i am assuming raw water cooling, not antifreeze and a heat exchanger. salt water? or fresh? the valve guides rot out and pass water direct into exhaust passages.
do not attempt to start the engine,as stated in an earlier post,the cylinders may be full of water,you don,t want to hydraulic the engine,pull the plugs and turn engine over by hand,use a long ratchet and a 3/4 socket on the harmonic balancer bolt.if you found water in some of the exhaust ports,id bet some got in some cylinders.
I've already cracked it up and it starts just fine, you think the valve guides might be rot? They only had around 1 hour of use since the rebuild
I had a friend with an old woods truck with no manifolds on it and he started it and the noise and fire shooting out of the heads put me to my knees I was laughing so hard (with my ears plugged), I can only picture it in an engine compartment!!
Get a set of manifolds and be done with it |
Am doing a compression test tomorrow to seehow things are
Just did the compression test and every cylinder was at 118-120, I did had water in the spark plug of cylinder 1
I'd pressure test the manifolds for confirmation. To do that plumb city water to an inlet nipple, plug any outlet ports. Then turn on the water and watch for water to appear in the exhaust gas section of the manifold. It will be obvious if they are leakers.
plug all the water ports, leave one to install a guage and a shrader valve like on a tire you can add water to the manifold just a little so you can see water pressureize with air and watch the guage with air pressure a leak is more to show up because the heat expands any crack while the engine is running, good luck had the same problem with a set it was spraying water on the exhaust valve and bending it only way i found it was with air pressure aprox 13 lbs should do it.....
This manifolds have no way to pressurize them..
Here where the water comes out of the manifold there's no way to plug them
http://i21.photobucket.com/albums/b2...psf97ddd26.jpg |
(Post 3852617)
go easy on the city water pressure so you don't blow them beautys totally apart, we use a gauge and put 7 lbs thru as our well kicks out 60 lbs. sounds like he dodged a bullet with the good comp #s time for a oil change and a new set of headers .
Jeff A. My KEs have held city water with thier thin walled cast aluminum. I will say I was a bit nervous the first time I did it but no problem. My thought is headers may need a good amount of pressure to show a leak cold as they may only leak when hot. If you cannot figure out how to plug your exhaust then I'd surely try to get a pressure test on the cooling system of the engine. Without knowing either the engine tests tight or the manifolds leak you are just guessing it will be fixed. |
(Post 3852678)
http://i21.photobucket.com/albums/b2...psf97ddd26.jpg Worked for me to test my Lightnings! |
Originally Posted by Budman II
(Post 3853080)
It might be easier to pressureize the exhaust side instead of the water side. You can get a good, flat, heavy piece of wood or even better, a piece of flat steel plate, and lay a header gasket against it to mark where the bolt holes would be. Drill out the holes, get a set of header bolts and 3/8" nuts for the back side, and bolt the header or manifold to the plate with a good header gasket (a piece of flat rubber would work well as a seat too). On the other end where the exhaust exits, install one of those 4-inch rubber plumbers plugs that snug up with a bolt or wing nut. A little lithium grease helps with a seal here. Then drill and install a schrader valve in one of the exhaust ports on your flat stock jig, pressurize with air, and listen for leaks. You can put a tire gauge on it to note the pressure, and let it sit overnight to see if it holds. A little bit of soapy water around the flange and plug will tell you if you are leaking air in those areas if it does not hold air.
I took the manifolds connected the hose and as the water was coming out of the ports that it meets the exhaust part the water kind of repels back down the exhaust
Part the spraying pattern causes it to create water reversion |
| All times are GMT -5. The time now is 06:40 PM. |
