-   -   Vacuum gauge installation 500hp carb (https://www.offshoreonly.com/forums/general-q/290343-vacuum-gauge-installation-500hp-carb.html)
speedfever 01-19-2013 01:29 PM
I have a 1997 Fountain with twin 500hp carb motors all stock. Where is the best place to connect a vacuum gauge. There is a rubber line that comes from the front of the base plate on the carb and goes to the left side under the electric choke. Can I tee off of that line or is there a better place. I cannot find any ports on the manifold or any other places on the carb.
dsparis 01-19-2013 01:39 PM
Theres two types of vacuum, ported and manifold. You need manifold. At idle pull off vacuum hose and check for vacuum. If it has vacuum at idle its manifold, tee off and use it.
MILD THUNDER 01-19-2013 01:47 PM
How about a tee in the line that goes to the pcv valve ?
speedfever 01-19-2013 01:48 PM
I cannot start the engines until spring. They have been winterized. The gauges are already in the boat but they are not hooked up. I just want to hook the gauges up so everything works.
the deep 01-19-2013 01:50 PM
At the very top of the intake manifold in the front there is a plug , pull it out and screw in the proper size nipple . If you use the one on the carb make sure it is located below the throttle plates . Why do you want to measure vacuum ?
speedfever 01-19-2013 01:53 PM
The PCV hose is braided stainless. I could use that line but I would have to find the right fitting to adapt without screwing anything up. That line is very ridgid. I guess I am looking for a easy fix,,,,,yea right !!
MILD THUNDER 01-19-2013 01:56 PM
Then i'd use the port that ''the deep'' mentioned. Remove plug, insert proper fitting
speedfever 01-19-2013 01:58 PM
I bought the boat last fall. At one time in its life it had blower motors and it had fuel pressure and vacuum/boost gauges that were left in the console but are not hooked up. I want to hook these gauges up so everything works.
MILD THUNDER 01-19-2013 02:00 PM
I may have some fuel psi electric senders available, might go mechanical on my fuel psi.
speedfever 01-19-2013 02:02 PM
I didn't see that port. Not saying that it is not there. I will check it out. Sounds like the easy fix that I am looking for.
thanks. I will post what I find.
the deep 01-19-2013 02:04 PM
I like it when they read on the BOOST side ! :evilb:
speedfever 01-19-2013 02:05 PM
My fuel pressure gauges are Gaffrig 0-15 psi.
FIXX 01-19-2013 02:05 PM
if its a true hp500 use the port behind the carberator thats threaded into the manifold..
That would be nice........lol
MILD THUNDER 01-19-2013 02:06 PM
mine too
the deep 01-19-2013 02:10 PM
That's the one used for the PCV valve bro . The one on the front side has a plug in it .
speedfever 01-19-2013 02:29 PM
I originally posted this question at 2:30 pm today. By 3:00, I have got a bunch of replies to help me with this. This is why this is such a great website !!!!!! Thanks everyone for the replies. It looks like I have several options to check out. I will post what I find.
speedfever 01-20-2013 12:30 PM
I found this plug. It is right under the baseplate at the front of the carb. 3/8 npt brass plug. This is the easy fix that I am looking for to hook the gauges up. I found the brass fitting that I need at Lowes.
Thanks for the tip
jeff
JoCo32 01-22-2013 06:18 AM
I have the exact same boat and setup. Fountain used the port under the front of the carburetor baseplate. Mine had 1/8" clear plastic tubing running to the guages. I removed it all so if you need anything let me know.
