Originally Posted by CAPTAIN JACK
(Post 3853681)
About the lifters, well I heard the factory lifters don't like that much, I got the Lunati cam damn near the same, 234/244 .629/.612 114 LSA 112 ICL and I called Lunati for the recomended lifters because I wanted to go with the cheaper street rollers with the link bar for $300 and some change, I told them what I was going to use it for and they suggested I go with the High RPM ones that are stronger and can take a beating, but they were $600. Well either it was good advise or a sales pitch, I went with the $600 ones, I guess for me it's cheap piece of mind. Just my 2 cents!! Hopefully the motor people will give some insight on this. Thank to the guy's that have given me advice!
I have a buddy running the morel street lifters in his engines. No issues with them so far. PS. The lunati, howards, PBM, are made by Morel. I don't think its snake oil. Lunati gets the lifters from morel. I doubt the sales/tech guy is making out by selling us the more expensive lifter. Their profit is probably very close for either set of lifter. Im sure if you called them and told them you were building a 900HP blown deal, they'd recommend their forged crankshaft and not their cast crankshaft. But if you called and told them you were building a mild 400HP big block going in your molestor van, theyd suggest their cast crank would be suffice. :bunnydance: |
Lifters it is then.
Thanks |
I have a similar cam in a 524 with the AFR 305's with the CNC'd chambers and bowls at 10:1 compression. I did a gasket match and runners myself. I went with the Morel lifters, but I have a set of Crane 13532's with 50 hours on them that I would let go cheap. I have a 280 also, so far I've hit 90 with 4 adults and a full tank. Still have a lot of tuning to do hope to be in the mid to upper 90's when done.
Originally Posted by cp5899
(Post 3853726)
Lifters it is then.
Thanks |
Thisislivin, that's basically exactly what I'm wanting. At the point I change the heads I'm hoping for 90. I talked to Steve stepp and he said with 600hp or close to it I should be in the 85-87 mph range.
What's wrong with the crane lifters you have? Are they not heavy duty enough? I'm Interested in picking the lifters up if they can work for me. Pm with price and details. I may call bob this week as I'm getting real close to getting all my parts. Thanks |
(Post 3853902)
Thanks budman. Ill have to check out the details to make sure they will work.
Thats pretty close to what I had in mine when I had the 088's on it. 509ci, same JE pistons. 236/244 650/603 112 LC Made 580/605 on dyno One more question is about the lifters. These lifters only have 60 hours on them, but not sure if they will work with this size cam. They are the factory lifters that come with a 502 mag (gen 6). They don't have the link bars. I realize each motor may be different, but were you guys able to run the factory style lifters or did you have to go to link bar lifters? About the lifters, well I heard the factory lifters don't like that much, I got the Lunati cam damn near the same, 234/244 .629/.612 114 LSA 112 ICL and I called Lunati for the recomended lifters because I wanted to go with the cheaper street rollers with the link bar for $300 and some change, I told them what I was going to use it for and they suggested I go with the High RPM ones that are stronger and can take a beating, but they were $600. Well either it was good advise or a sales pitch, I went with the $600 ones, I guess for me it's cheap piece of mind. Just my 2 cents!! Hopefully the motor people will give some insight on this. Thank to the guy's that have given me advice! The “Street” lifter is a cast body with a .700” wheel and has a place as an OEM replacement lifter. It is not designed for longer duration (23x+) camshafts and the valve spring rates, seat, and open forces required in a performance marine application. The performance lifter has a steel body with a .750” wheel and is “good” to ~ 6500 RPM and 200#seat/500# open. The High RPM lifter is a billet body lifter with a .750” wheel which I have personally seen run well in excess of 7000 RPM. The .903” version will feature a .810” wheel, which combined with a 55mm+ core will open new opportunities in hydraulic roller cam development. I would caution you regarding the economy of running used valvetrain parts, or OEM components that are outside their design specification, in marine performance applications. Regards, Bob |
Originally Posted by ThisIsLivin
(Post 3853857)
| All times are GMT -5. The time now is 12:24 PM. |
