1997 scarab 29 ft
looking to buy my first speed boat, and I found this 97 scarab with twin 350 mpi stock . is this a good boat for a first timer. and is this a good boat in general?
It's a good boat. Not so sure about for a first timer though. Not saying you couldn't do it. IMO a first timer would be something in the 18-24' range with a single engine. It's also going to depend on how mechanically inclined you are and where you will be useing it.
That will be a great boat for you.. Built like a tank, not too fast and if you blow an engine, a 350 is cheap.. Just don't expect a 70 mph boat.. I think it will run in the 58-61 range. What are they asking for it.
Chris |
Originally Posted by Blueabyss
(Post 3860041)
Chris |
Originally Posted by picklenjim
(Post 3859944)
Scarab made some good boats, so unless it hasn't been maintain properly, it should be a good boat. If you are boating on large bodies of water, which sounds like you are, twins will usually get you home when one motor has a problem. No more getting towed home. It will take a while for you to get used to the sticks, but twins are better when around other boats and in windy conditions. More to learn, but I wouldn't be afraid to buy it for that reason.
Everyone told me not to get my 302 scarab as a first boat and I had no problems. You just need someone to take some runs with you in the beginning to give you some tips. You have to watch for transom/stringer rot in that boat - that would be my biggest concern.
| All times are GMT -5. The time now is 11:36 PM. |
