What blocks do I have in '93 Fountain?
I have a 1993 Fountain Lightning with stock powered Merc. 502's. What Gen. Block would these motors be?
fixx
Originally Posted by ruepappy
(Post 3861027)
Fixx is right. 1993 should be Gen V. Timing cover will tell the story.
I think some early 90-92 era 502 blocks were actually Mark IV bowtie blocks. Even the 502 mags. |
It should be a Gen V. If it does not have a fuel pump mount on the engine block then its is a Gen V.
If it has the fuel pump mounting spot on the block, then its a Mark IV. |
My '93 has 5's
Originally Posted by mrfixxall
(Post 3861032)
if stock power their gen 5's or V and the timing cover wuld be steel..if they were changed the timing cover would be plastic and those would be gen 6..both 6 and 6 use the same internals except for internal valve trane,,5 is hyd flat tappet cam and liftersand 6 is hyd roller cam and lifters...1995 is the cut off date,,so a 95 boat could have either engine..
Originally Posted by Griff
(Post 3861119)
Originally Posted by rrentsch
(Post 3861327)
Dose the plastic timing chain cover also apply to 2000 500efi's
(Post 3861473)
ye,all gen 6 has plastic timing cover..
fixx
Originally Posted by HaxbySpeed
(Post 3861526)
It's actually cast aluminum..
Lmao!
i have one in my little shop right now,it is definitely plastic.
Originally Posted by mike tkach
(Post 3861627)
The gm performance gen vi covers are listed as cast aluminum. I have a stock gen vi 454 in my dually, ill have go out to my little shop and look at it. Lol
fixx
(Post 3861637)
Weird, what engine is it? I just went downstairs to my little shop in the basement and checked 7 different ones, all aluminum. 575sc's, 502Mag, zz502, etc. I'll check some more when I'm at the shop tomorrow. Maybe there's some plastic ones on different years? I've ever seen one, but I'll check now 'cause I'm curios.
Ok, did some surfing. Seems like the production gen vi engines, received plastic timing covers. The gm performance 454HO and 502HO crate engines got the aluminum covers. My guess would be look at a 7.4L mpi merc 310hp, and you'd probably see a plastic cover, since its more or less a L29 production engine. The 454 mag, 502 mag, HP500, and so on , would more than likely have a aluminum cover, since they were not automotive production engines in base form. Which would make sense why haxby is seeing the alum covers.
Here's the aluminum cover http://www.gmpartsdirect.com/perform...CATID=344.html |
this one is a gen 6 502,i dont know what year it is,it has been apart before because it has aftermarket hyd roller lifters with the link bars that would not be necessary with the stock 415 horse cam that was in it,also it was .030 overbore.
fixx
Originally Posted by MILD THUNDER
(Post 3861652)
I bought 2 new crate engines for my Gibson a few years ago, Gen VI' have alum covers...
my 2000 model gen 6 502 mag's are alum.
my boat is a 1993 and was equipped with a 502. it had a manufacturer date of 1992 and is a gen 5. gen 5 engines in mercruiser setups have larger oil lines. it will have a flat tappet cam... mine had 5 flat lobes when i took it out a few years ago.
| All times are GMT -5. The time now is 04:31 AM. |
