-   -   Stereo question (https://www.offshoreonly.com/forums/general-q/291812-stereo-question.html)
Crude Intentions 02-19-2013 02:53 AM
Stereo question
Looking at the Sony dsmxs60 head unit. On fleabay for 235 comes with wired remote. My question is if I bought a second wired remote can I wire both into one head unit. Not sure if the regular remote will work from helm with radio in cabin and I want one out by swim platform. Ultimately I may need 2 wired remotes. Never had a head unit with a wired remote so my knowledge here is limited.
Thanks for any responses.
Drock78 02-19-2013 05:42 AM
On my clarion they make a splitter to run 2
Crude Intentions 02-19-2013 06:01 AM
Thanks Drock. After reading your response an leaning on my old friend google I found Sony does the same thing with y adapters. Problem solved!!
US1 Fountain 02-19-2013 09:38 AM
My Sony just uses standard Y's I bought from RS. I had 2 wired remotes, dash and transom. The dash had a display which used a sep wire lead for that feature, but the operations wire controlled by standard phono cable
commandersander 02-19-2013 08:04 PM
Mike.....
Which remote? There are two for marine application, one has a display, one does not.
The one without needs only a 3.5mm y. The one with needs a 3.5mm AND a unlink y.
Either way, I have the parts here in the garage....as I should...seeing as how I designed them :eekdrop:
