Free Air Subs.....opionions??? >
Old 02-19-2013 | 01:39 PM
I know about Omages, and wireing it correctly. Right now its a 2 channel amp, powering a left and right side at 4oams. that how it came.
I need to wire them in paralle, and put amp in MONO and see what happend. but have not messed with it yet. just know the subs pop will start jumping pretty good and pop easy.. so figured the speakers where the weaker link at this point.
mittens is offline
Old 02-19-2013 | 02:30 PM
i have 2 of these 12's in the front of my htm ss24 mounted on a verticle wall. behind it is the front empty space of the front of boat. tech specs say these are ok to use as free airs. here is a link and this was also the cheapest place i found to buy them. i think they sound awsome but they do require so power to push them and be sure they are wired correctly. they have switches on speakers for running 2 or 4 ohms.
http://www.sonicelectronix.com/item_...pa-120.9W.html
La/stryker is offline
Old 02-19-2013 | 02:31 PM
That is not going to work with most amps. two for 4 ohm speakers wired parallel is a 2 ohm load, when you bridge an amp it sees half of what ever load you give it, You are effectively now at 1 ohm. most amps will pitch a fit at that load. You need either 2 x 2 ohm speakers wired series to give you 4 ohms and then you can bridge the amp (or just run each channel at 2 ohms) or 2 x 8 ohms speakers wired parallel to get to 4ohms then bridge the amp. Or 4 ohm dvc speakes can do either etc. or you can just add 2 more of the same speakers and wire a combo of series parallel to get to the desired ohm load if the amp is big enough. Lots of ways to skin the cat.
professor_speed is offline
Old 02-19-2013 | 02:40 PM
they look cool too, i would send a pic but cant get it to load.
Old 02-19-2013 | 02:47 PM
your thinking is 1/2 right
2 X 4ohm speakers in Parrallel is a 2 ohm load. (not 1 ohm)
the amp is a 2 channel amp, 2 channels @ 4oohm each or a MONO channel stable @ 2 ohm's
Right now, its wired 2 channels, at 4ohms each.
I need to try them in parallel, and the amp Mono/Bridged mode. for a 2 ohm load.
mittens is offline
Old 02-19-2013 | 03:02 PM
We sell all the brands mentioned except Wet Sounds and can say, handsdown, the JL M10IB5 is the sub you want to go with...in the right space. None of these subs will sound worth a dang if they're not located in the right spot and have the right power going to it. The Rockford is going to be my next pick but I really like the Rockford sealed subs....they are amazing pushed by a JL amp...not a big fan of Rockford's marine amps. The Jl sub will run very loud and clean off of low power and is our choice for marine installs. The Rockford just sounds awesome in a sealed enclosure and even better than the JL sealed sub. Let me know if I can be of any further help. The alpine sub just doesn't even rank in this comparision...same with the Memphis and we sell both.
xtremeaudioky is offline
Old 02-19-2013 | 03:28 PM
See my buddy just told me the Alpine is better then the JL.. and he is a HUGE Jl supporter, but the alpine does a damn good job, and is 1/2 the price.
mittens is offline
Old 02-19-2013 | 04:06 PM
when an amp is bridged is only stable at half its rated stereo load, 2 ohm stable stereo is only stable to 4ohm bridged. that is cause the amp sees half the load, The amp is actually running its channels parallel when bridged. On old amps you would actually run off of the + on one channel and the - of the other channel to bridge, most newer am just use a switch and handle this internal. So yes technically the speakers are wired up to present a 2 ohm load but the amp will effectively run half of what ever load it sees when bridged.
This is why a stereo amp can put 4 times its single channel stereo power. 2 channels become 1 (this doubles the power) and the effective load become 1/2 (again doubling the power) for an amp to be 2 ohm stable in bridged operation it must 1 ohm stable in stereo operation. Most are not.
(Note not all amps double the power this will depend on how well regulated the power supply is)
Old 02-19-2013 | 04:12 PM
http://www.jlaudio.com/jx360-2-car-a...plifiers-99399 Click on the specifications.
Here is an example of how power will change and how what ohm loads an amp will typically handle change as the amp is bridged or presented with different loads. notice the amp will take either a 2 or 4 ohm load in stereo but only 4 ohm bridged.
Old 02-19-2013 | 04:30 PM
MOST big car amps when I used to do stereos, where stable to 2 ohms bridged. this is what I was assuming.
if the amp is stable at 2 omh bridged, and I run 2 4ohm subs in parallel thats the correct load.
mittens is offline
