-   -   anyone have an '82 40' Excalibur Hawk? (https://www.offshoreonly.com/forums/general-q/292079-anyone-have-82-40-excalibur-hawk.html)
whiskeyhangover 02-25-2013 07:47 AM
Does anyone out there have one of these boats? We are in
the process of bringing the one I have back to life and running
into some problems... thanks!
adk61 02-25-2013 08:07 AM
PM Jamie.. lilred, see if he wants to part with his... sweet boat
whiskeyhangover 02-25-2013 08:24 AM
ok.... we just needed to know where the fresh water hold tank is and the best way to get to it. The line that feeds the sink is clogged up and a fish tape won't unclog it so we need to get to it. We believe it's underneath the teak wood floor and need to know a good way to pull that up as well without destroying it.
Unlimited jd 02-25-2013 09:04 AM
My cabin has been completely reconfigured, and there's no longer a sink. But I can do some digging today and let you know the best way to get to the water tank. Btw, don't just reach up and put fuel in the boat at a gas station..... Make sure the nozzle is in the fuel fill not water..... Doh!!!
MILD THUNDER 02-25-2013 10:21 AM
I had a 82 hawk. I don't remember where the water tank was for the life of me. If indeed it is under the cockpit teak floor, Id probably get another tank and mount it somewhere else rather than pulling the floor up. That would be a project.
Is there water in it now? Maybe you can try putting some compressed air back into the line to break the clog free?
whiskeyhangover 02-25-2013 10:52 AM
ok lil red any help would be appreciated!
mild thunder that's a good idea, we'll try that.
FIXX 02-25-2013 06:18 PM
i used a pressure washer to unclog them,,works good with the million little air bubbles to wash the line out..first check the filter at the pump,,they get clogged with mold!
Unlimited jd 02-25-2013 07:04 PM
Good new is I was able to follow the full hose most of the way down. Bad news I lost it when it went under the cockpit floor..... So yep tank is under the floor
whiskeyhangover 02-26-2013 01:05 PM
that's what I was afaid of... I woyld lie to get to it to see if it's plastic
or metal, because if it's plastic its probably no good now and it need
to be replaced...
