Keith Eckhert 2 stage water/sea pump!
Anybody have these? If so, do you know if they take standard Mercury impellers?
I dont have mine apart yet to verify, but would like to do my impellers this spring and wanted to order them ahead of time. ON KE's website (CP performance too) they have impeller kits for $140!! Seems a bit pricy when MERC ones are $30 each. If I know theyre the same, I'll just pick up some of those. Any help would be greatly appreciated! |
yep; and they take standard Merc impellers & wear plates and quite a few O rings.
Mercury impeller part # 47-59362
The wear plates also have specific holes drilled in them along with the o-rings. If you have the older style KE pump with alum. housings and stainless steel inserts, be prepared if corrossion has imploded the stainless insert.
| All times are GMT -5. The time now is 11:47 AM. |
