-   -   Head gaskets (https://www.offshoreonly.com/forums/general-q/292945-head-gaskets.html)
streetrodchris 03-13-2013 01:15 PM
Head gaskets
I have a 502/540,,,what is the fel pro part number for this? Had the heads totally reworked. Thanks Chris J.
Rookie 03-13-2013 01:19 PM
Fel-Pro 17048 is a great gasket for your application.
HaxbySpeed 03-13-2013 03:57 PM
That gasket works great as long as you're still running a 4.500 bore. You can save yourself $30-$40 by ordering #1047. It's the automotive equivalent and comes in a different wrapper but it's identical and has the 17048# stamped right on the gasket.
MILD THUNDER 03-13-2013 04:03 PM
Bonus! Good info.
F-2 Speedy 11-28-2015 05:18 PM
I just tore a couple of gen 6 502's apart and they have the 17048 gaskets, so I went on Summit's web site and the 17048 is a dollar cheaper than the 1047....I know this thread is two years old, someone must of tipped them off.
Baja Rooster 11-29-2015 05:24 AM
What's the difference between the 17042 and 17048? Std bore 502.
F-2 Speedy 11-29-2015 10:23 AM
the 17042 is for a 4.370 bore 454.... and the 17048 up to a 4.540 bore 502 or 540 depending on rod length and stroke...........that's how Summit has them listed
Baja Rooster 11-29-2015 12:20 PM
That was my thought, and thanks for clarifying.
