Need urgent help from an expert
Hi,
I am closing to buy a 2002 Stingray with a Mercrusier 6.2 Liters. About 500 hours. Do I have to be worry for anything with the engine? Normal maintenance done regularly. Thank for your kind, help Andrea |
At that amount of hours I would request a compression test be done on the engine, that will tell it's relative "health". It may cost a hundred dollars or so but could save thousands. Also all fluids including the drive should be checked by a qualified technician, that will show a lot.
Thank you I really appreciate
Andrea |
I honestly don't know much about the ''stingray'' boats, but for some reason in my head Im thinking ''poor quality''. I could be totally wrong, maybe I misread something in the past, but might be worth asking or researching that brand.
I had a 230 sx, a lot of performance for the money, but the build quality was about as bad as my hawk. EVERYTHING fell apart when it was a little rough. Great inland lake or pond boat, not a bay or ocean boat by any means.
A compression test and drive check are certainly good advice.
If it were me, I would also ask the tech how much to scope the camshaft. It never lies. Cheers |
I know nothing about the boat but 500 hours on 6.2s is nothing.
Salt water? its due for manifolds risers and possibly heads. Fresh you are fine if it checks out.
Look for spider cracks on the bottom of the hull . Climb under and have a good close look .
Also look for spider and spider monkeys in the cuddy.. its a common problem
Yes big spider monkey problem!
Seriously I can say there were little to no spider cracks in mine. |
tuliping the valves a issue on small blocks with that kind of hours...as said before compression test would help ck that...
The last thing you need to worry about in that boat (or most boats) is the engine and drive. You are worrying about the strongest link in the chain. If it is fresh water 500 hrs is nothing.
Originally Posted by Element 13
(Post 3886488)
Originally Posted by ICDEDPPL
(Post 3886530)
Originally Posted by mike tkach
(Post 3886643)
I have never heard of scoping the camshaft,can you give some inforation about that?
Also the OP is 5/10 on on the Darr meter, interested to see where this ends up |
| All times are GMT -5. The time now is 11:43 PM. |
