Is this piston usable?
2 Attachment(s)
Planning on doing 540's in the next year or two so just trying to put together current engines on a budget. The cylinder has pitting in it due to a poorly installed intake manifold gasket that not only allowed water into engine but also had a 1/2" split in the #7 cyl. I'm planning on having that cylinder sleeved this week but was hoping I could still use this piston. It has small pitting likely due to the water that sat in it. These are 60 over JE's. Will be using all new rings.
I personally wouldn't use it. You can just buy 1 piston
Originally Posted by MILD THUNDER
(Post 3887469)
fixx
looks like salt water dammage,,like mentioned i would not use it..if they are je castings inside then sent it to them and they can match it..
Correct me if i'm wrong but shouldn't he weigh the old one vs the new one and have them matched in weight?
fixx
Originally Posted by sonicss42
(Post 3887496)
Not with the side skirt being damaged. I would be getting a new piston.
two questions.....
1) how much is a new piston??? 2) how much is it going to cost to rebuild the motor if the piston comes apart at WOT and the rod is bouncing around??? |
As mentioned, replace the piston. Based on the specs you gave, the piston should have a compression height of 1.645 (9.8 block, 6.135 rod). It's just a standard JE flat top in 4.530 bore. Order part # 257985.
Eddie |
I'd use that piston .Saw it through the wrist pin hole and make an ashtray
| All times are GMT -5. The time now is 09:37 AM. |
