Rod bolt stretch specs needed
Does anyone have the rod bolt stretch spec for the ARP bolts used with the Eagle I-beam rods? These are the cap-screw bolts. I found torque values on Eagle's site for 63 ft lbs, but want to use stretch instead.
Thanks! |
the 8740 bolt stretch is 5.9 to 6.3.arp sais 63 lbs of torque will give you the desired stretch when useing arp ultra lube.
Originally Posted by Budman II
(Post 3887979)
Thanks! Wait a minute; do you have a I beam SIR rod, or a H beam? |
Originally Posted by MER Performance
(Post 3888215)
ARP 2000 or L-19 ?
Originally Posted by mike tkach
(Post 3888064)
(Post 3888230)
Mark, they are the I-beam, not the H. They are not the L-19, they are 8740, 1.75" length under the head, 7/16 head and thread size, IIRC.
It will require more torque, even with the ARP lube to get the stretch. I would take it to .006 & stop. |
(Post 3888290)
Mike, is correct. even for the SIR rods the stretch is .0059-.0063. Just spoke with Eagle.
| All times are GMT -5. The time now is 03:40 AM. |
