-   -   Blow By Out The Breather (https://www.offshoreonly.com/forums/general-q/29341-blow-out-breather.html)
sheikman 07-24-2002 05:35 AM
blow by
I have a 140 thermostate, what would be the correct thermostate to install ???
Can I use a 180 or should it be higher ????
Sheikman
BAD-HABIT 07-24-2002 08:19 AM
Stock is a 140 or 160. I wouldn't go any higher than a 160....
"Bad-Habit"
sheikman 07-26-2002 10:44 PM
Blow by
Thanks for all the suggestions.
Found a leak between the manifold and risers.
Aluminum EMI Thunders, with stainless bravo risers.
Used Indian Head Sealant and it did the trick.
Sheikman
