-   -   baja stereo help (https://www.offshoreonly.com/forums/general-q/293462-baja-stereo-help.html)
ckcgobigblue 03-24-2013 12:50 AM
baja stereo help
I have asked questions before but I still need help. Im trying to upgrade my stereo but am trying to do it cheapest i can. I dont need the best stereo but want a decent one and my biggest priority is hearing it in the water when we are anchored or tied up. I just bought 2 comp 12s to put under rear bench. Should I just mount them free air or try some kind of boxes? Im also leaning toward polk mm 6.5s but like I said I want best set up for listening in the water. Ive considered speakers on transom but it scares me? Anyone mount speakers on dash beneath windshield? Or have speaker boxes they put on sunpad when parked? Any info is appreciated and thanks
Griff 03-24-2013 01:34 AM
If you want to hear the stereo when you're in the water swimming, the best option is to get some extra speakers that you can set out on the hatch or swim platform.
Get a couple DC Gold's and put them in a small box. 100% water waterproof.
BIGBREW 03-24-2013 03:58 PM
Add big amps!
ckcgobigblue 03-24-2013 09:27 PM
Im gonna try to run everything off one five channel amp so that it doesnt drain my batteries too much
BIGBREW 03-30-2013 12:33 AM
depends on what type of amp you run, a good amp will draw less power than a junk amp, Unfortunatelly I put 1700 watts of Rockford Fosgate amps in my Checkmate Convincor 270 last year, Its pretty loud when the exhaust is turned off and I am putting out of the bay. As soon as the exhaust switch flips and I throttle up, I dont care how much money I spent on stereo equiptment, You cant hear it.
whoya 03-30-2013 05:25 PM
I have a 89 baja 23'5 and put a set of 6x9's in the rear of the bolsters. Im talking about where the vinyl covered wood piece slides around/into the bolster(at least on mine). Had to open the inside(plastic) for the speaker to sit all the way in. Its points the sound out towards the stern and is up of the floor and mounted.
whoya 03-30-2013 05:33 PM
1 Attachment(s)
Little dark but here is a shot of them.
1989mach1 03-30-2013 06:30 PM
i was the same way with my 27. i just got all my speakers form walmart online and it sounds good. i have 2-6/9s 2-12's and 4-6/1/2s with tweeters. with a amp and all i think it was under $500.
Full Force 03-31-2013 08:48 AM
Craigslist is your friend, I have mostly used stuff and a few new things, I have under 1500 in whole thing and its all JL and Alpine top of the line...
I have 4JL 10's
4 Alpine type R 6x9's
2 Alpine type s 5 1/4's
2 Alpine type r tweeters..
JL 1000/1
JL 300/2
JL 300/4
this stuff new would be well over 3000.00 and it is FUKKING amazing sounding....
I got all amps and subs from craigslist, the Alpines are akll new...
you build a hell of a stereo for not a ton of money if you do it right
oregondunes 03-31-2013 04:19 PM
the more efficient amps made are Krypt. dont let the "low" rating fool ya.
http://www.bulletlines.com/Marine-Cl...ier-p/4556.htm
http://www.onlyinboards.com/Accessor...l-Range-A.aspx
txtraveller2002 04-01-2013 12:44 AM
I have 4JL 10's
JL 1000/1
JL 300/2
JL 300/4
gotta agree with the CL thing...also, check Ebay. The one thing that is awesome about buying off Ebay anymore is stereo stuff, everything else pretty much sucks.. Sonic electronics is a big dealer on there, and they have pretty good prices on high end stuff. They have their contact info on their auctions, and you can call them and get a little better price than advertised. If you can't find anything there, then CL it.
Randy Nielsen 04-01-2013 02:42 AM
+1 for E bay I bought 2-700+5 & 2-450+1 JL Audio amps, 4 Rockford Fosgate 10" subs,4 RF 8" & 8 6.5" 2way speakers with a Kenwood head unit & 2 31 series stereo batteries all the amp & speaker wiring, fuses, etc for just over $2000.00. It should get loud enough if I mount the speakers correctly. I think the 6.5s up as high as possible, the 8s above the floor on the sides & the subs in boxes under the back seat. Otherwise I will have a lot of stuff for sale!! LOL. Randy
ckcgobigblue 04-01-2013 04:13 PM
Yeah I plan on using eBay for pretty much everything I buy. Did all of you guys install everything yourself or pay someone? How hard was it if you did it yourself? Did you guys buy sub boxes or build them? Was wondering how mdf boxes would hold up under rear bench. Thanks
whoya 04-01-2013 07:31 PM
Did all my own. For subs I pulled my rear bench seat out and put a piece of wood close to down the middle to get it close to the recomended air space (4subs). Not sealed though due to needing access to motor(sliding foward) and seat cushion comes off. It sounds very good though.
Randy Nielsen 04-01-2013 10:45 PM
I plan on doing the work myself with some advice where needed. Just bought some seats for the front & want to make the rear similar. I will be looking for advice on building sub boxes under the back. When my shoulder gets better I will start a thread on this boat so I can show what I'm doing & listen to others ideas & experience. I did that with my Kachina last fall & got a lot of advice & ideas. Things work pretty well when experience & ideas are shared. Randy
Full Force 04-02-2013 05:28 AM
I like free air in a boat, boxes take up way too much needed storage space... buy quality stuff, not junk...
