Where to buy air hose for silent choice?
Looking to by a roll of silent choice air hose to relocate a silent choice pump. Any suggestions as to where this could be purchased?
I found clear 1/4" OD tubing at True Value Hardware and thats what I used. It was cheap and works fine.
The clear is ok as long as it does not sit in the sunlight.
Jon |
I have seen on motors in blue and red.
Ice maker water line
I just used the semi-rigid plastic tubing that is sometimes used to plumb ice-maker lines. You should be able to buy it by the foot at any home improvement store. You can also get the brass compression fittings for it, probably in the plumbing aisle.
The official stuff is available at any Mercruiser dealer, you get a huge bag of the stuff for about 10 bucks, no fittings though...Doug
Home Depot saves the day again. Bought the hose there and reused the compression fitting from the old hoses. Works great.
Many thanks, Dave |
| All times are GMT -5. The time now is 02:27 PM. |
