Originally Posted by soldier4402
(Post 3897283)
I guess thats something to look into. You may also look into weight savings.
thats pretty good, specially for a 24 foot boat, i dont know how much fast you would want to go as far as safety in concerned, but racing might be a different story
(Post 3897319)
It handles perfectly and feels 110% safe at these speeds so a few more MPH wouldn't hurt. |
Originally Posted by tomas_wallin
(Post 3897345)
I want to go as fast as possible :D For the moment there's no one that has been as fast in a 24 Pantera with a stock, non racing engine before.
(Post 3896983)
Thanks Steve,
What viscosities work with the 496 Mag HO then? Is it 50 and nothing less? it isn't a function of engine type. it is a function of mechanical clearences. you need to talk to the builder and se what he used. if he used the factory clearences then you are , essentially locked into what the factory reccomended. if he tightened them up up can use a hi grade thinner synthetic. if he opened them up you may very well be locked into a heavier single grade like a 40 or 50. it is all defined by the clearences. |
Tomas, give the guys a shout at Alisyn Oil. They've got some great products, including a zero weight gear oil among several other types of oil and lubricants.
We used to run the zero weight in the outboard drag boats to help get the last little bit out. ;) Crazy stuff, because it's got the consistency of water! Nascar guys use similar in the rear ends of their cars from what I understand too. http://www.aerospacelubricants.com/alisyn/default.html |
Originally Posted by stevesxm
(Post 3897356)
It's a stock 496 Mag HO so I guess 40 will work since Merc sells 25W40 for there Sterndrive motors. |
Tomas, what numbers did you see on the dyno with the KE exhaust?
Originally Posted by onesickpantera
(Post 3897378)
(Post 3897379)
About the same as the Sport Tubes :whistle:
