-   -   Bravo coupler help (https://www.offshoreonly.com/forums/general-q/293977-bravo-coupler-help.html)
boatnt 04-03-2013 07:17 AM
Bravo coupler help
1 Attachment(s)
when do you know when a coupler is bad???
boat has 110 hours,,alignment is right on,,outdrive pulled out ok,,looks like it was never greased,,,cleaned splines,,teeth are still square,teeth might look slightly smaller than a new coupler,,installed a test drive shaft and has slight play side to side which I would think its somewhat normal,, I have no problem with replacing it but not sure its worth the trouble at this time,,
hard to really take a good picture
Knot 4 Me 04-03-2013 09:01 AM
Looks good to me. Grease it and go. I've seen them worse.
boatnt 04-03-2013 09:44 AM
thanks,,thats what I thought as well,,but I am bored and looking for things to do:lolhit:
Ted G 04-03-2013 09:55 AM
Looks okay, careful not to overgrease it when you go back together.
Knot 4 Me 04-03-2013 10:00 AM
Well then, I have a 496 MAG that would love to become a HO! :lolhit:
boatnt 04-03-2013 10:14 AM
really?? did not know that.thanks
boatnt 04-03-2013 10:16 AM
:lolhit:
FIXX 04-03-2013 05:34 PM
fixx
they are bad when the tip of the v part has a sharp edge..i would first clean the splines,this will make the coupler last longer if you can get all the matallic looking (silverish grey) grease out and use the heavy merc coupler grease in..dont just use regular grease,,it had not impact rating and will ooze out and merc coupler grease wont..
Knot 4 Me 04-04-2013 06:38 AM
^^^ I always use the blue Merc coupler grease.
boatnt 04-04-2013 06:46 AM
Thanks guys,,,
