-   -   Hydraulic steering ram install help (https://www.offshoreonly.com/forums/general-q/294202-hydraulic-steering-ram-install-help.html)
cp5899 04-07-2013 11:48 AM
I got a imco hydraulic steering setup from a member on this site. Everything looks god, but my question is about ram placement and drilling the holes through the transom. I obviously want to get the ram in the right spot. I would hate to think I drilled holes in the transom in the wrong spot.
Is there a pattern online some where? Or a list of demnisons on where to place the ram?
Thanks in advance.
737jetmech 04-07-2013 04:16 PM
If you go to www.imcomarine.com they have all the dimensions depending on the ram total stroke . measure twice drill once ! :)
cp5899 04-07-2013 05:02 PM
Thanks! Should have looker there first.
Think I'm going to measure 10 times and drill once.
mustangmark 04-08-2013 12:49 AM
++++++1!
just installed my imco ram about 2 weeks ago. Same as you, I bought the kit used. I went to imco's site and was able to look up the correct specs. The illustrations are great and easy to read!
