-   -   weiand 177 oil fill (https://www.offshoreonly.com/forums/general-q/294601-weiand-177-oil-fill.html)
wayne272 04-14-2013 04:55 PM
weiand 177 oil fill
1 Attachment(s)
Was wondering how much gear oil to put in the front reservoir of a weiand 177 blower. There is no dipstick on the top plug on the front plate (just a regular pipe plug), and there is also a vertical pipe plug on the front plate right under the weiand logo. I filled the rear reservoir (there is only 1 vertical plug on the back plate) with merc hipo gear lube up to the bottom of the hole.
PRIMECUT 04-14-2013 05:14 PM
Does'nt take much more then a few shot glasses of CPW supercharger lube to get to the bottom of the plug where a sight glass should be.
wayne272 04-14-2013 05:46 PM
definitely don't see a sight glass. Just the pipe plug on the front plate.
PRIMECUT 04-14-2013 06:32 PM
pull out the front plug and screw in a sight glasss , thats what that set of threads is meant for or just leave it out while your filling it and when it starts to run out she's full .
blue thunder 04-14-2013 08:11 PM
I believe the front takes 8oz and the rear 4 oz.
wayne272 04-15-2013 05:33 AM
Thanks guys
