-   -   Helm Pump advice for #6 drives Please (https://www.offshoreonly.com/forums/general-q/294915-helm-pump-advice-6-drives-please.html)
Velocity Vector 04-19-2013 11:24 PM
It's time for a Helm Pump for the cat project and I need some advice on the size Helm pump that I need. What Part number CharLynn Helm pump do I need for SSM # 6 drives on my Ocean EXpress? I don't want to buy one to small.:eekdrop:
Velocity Vector 04-20-2013 10:04 AM
ttt
Velocity Vector 04-21-2013 09:33 AM
Have I stumped the Whole board?
Rookie 04-21-2013 08:48 PM
You first need to find the volume of your cylinders rod side and non rod side. Determine how many turns you desire lock to lock. And then size the appropriate helm pump. I had a friend that liked his 6 turns lock to lock and I like my faster reacting 3 turns. (1.5 turns from center)
You need an Open Center / Non Load Reaction helm.
Some reading for you.
http://www.pirate4x4.com/tech/billav...ng/index2.html
This is the pump I use and it steers really easy when the engine with the pump is off.
http://www.midweststeering.com/index...=351&parent=87
Velocity Vector 04-23-2013 07:50 AM
Thanks, CP Performance hooked me up with the correct valve their # 137-9147 it's a 4 valve 230CC pump 4 turns lock to lock.
Rookie 04-23-2013 12:26 PM
Nice! That pump flows some serious oil. I assume with a 6 setup you have 2 cylinders/drive?
Velocity Vector 04-23-2013 05:19 PM
Yes 4 cylinders great ol big fat ones. You can also run on steering pump as long as you have a large enough reservoir but two pumps is better.
