Strange "dotted" pattern on valve seats and faces
We were going to install better springs / retainers along with inconel valves in my GM heads, and this is what 5 out of 8 intake valves looked like after 30 hours. The engine builder who took them apart said he has never seen anything like this in 40+ years of building engines. It almost looks like the valve was only sealing in spots on the face. Funny thing was, engine was running fine, and compression check showed 185+ PSI on every cylinder. One thing to note - valve tips all had lines on them where the rocker arm roller tip was beginning to wear into the stems - they were not rotating in the guides.
Pictures: http://i1224.photobucket.com/albums/...427_114541.jpg http://i1224.photobucket.com/albums/...427_114637.jpg Has anyone ever seen anything like this? If so, what was the cause? |
I have seen that before its usually from who ever faced the valves had a lot of chatter When they were grinding them. They needed to face the stone and regrind the valve. Titanium valves do that a lot when facing them if the stone gets loaded up!!!
Originally Posted by IRWIN
(Post 3917733)
I have also seen that. Agree with cutter chatter.
Jeff |
Not pointing fingers but lets just say the valves were not faced correctly!!! But it's a very easy fix. Have the seats cut and valves faced by a reputable shop and you will be good to go!!!
Agree, poor cut and appears no rotation.
Re-lap the valves, you`ll be fine.
| All times are GMT -5. The time now is 01:55 PM. |
