502 mpi running on 4 cylinders
Ran the boat today made a couple laps at WOT, headed back and it hiccuped so I backed out of the throttle then started running like s*** after putting a new cap and rotor and a coil still running the same
After some trouble shooting 2 cylinders are down on th port and starboard side Port side cylinders 1 and 7 are down Starboard side cylinders 4 and 6 are down Any ideas? I'm thinking a distributor but not sure |
sound like an injector wire feed from ecu went bad.
So is that the injector harness that runs cylinders 1746?
Originally Posted by tdpb2008
(Post 3919064)
Ok will do
How would I test these? And where
(Post 3919093)
I am looking at my wiring harness for another problem but you might check your grounds. There are 3 grounds on the injection harness alone. Randy
It's weird it was running great then it hiccuped and has run on 4 cylinders...they just all of a sudden go?
I just checked the spark and it does have spark on all cylinders
| All times are GMT -5. The time now is 04:50 AM. |
