Gen six 502 casting numbers
Hello all. I'm looking at a 502 and the casting number reads: 19165956.
I cannot find any info whatsoever on his casting number. I've searched for quite awhile and I have exhausted all the online info. My concern is that it is a generation six roller cam block. Is it a fact that only gen six blocks have the aluminum six bolt timing cover? Thanks, rob |
Yes, if it's a Gen VI block, it will have a 6 bolt timing cover. They are the only ones with that cover. If it's a Gen VI, it will also have a factory roller cam.
Eddie |
Vintage,
That is GM's latest ( and possibly last) iteration of the BBC block. The 19165956 casting number is not yet listed, however the part number is 19170540. Very nice piece. Description • Revised 502 Gen VI Bare Block • New casting incorporating the best designs of Mark IV and Gen VI • Production type cast iron 4 bolt main block • Improved main bearing bulkheads - Bowtie block style bulkhead • Clearanced for bigger strokes - up to 4.25" • 4.466" finished bore • 4.500" max bore • Siamese bores • Fuel pump provision has been added to this block • Revised water jackets for Mark IV or Gen VI heads • Revised oiling to allow for bigger cam bearings / cam lift • Bolt boss added to valley for use with dummy oil pump drive (Like 8.1L) • Additional clearance added in front cover are for roller timing sets • Additional oil pressure port added to front of block • Racing style oil filter cast feature with added oil pressure port • Two bosses added for manual transmission clutch pivot (A, B, F, X car boss & '63- 82' Corvette boss) • Additional material added around lifter bores • 9.800" Deck Height • Bare weight 269 Lbs. Bob |
Man! Thank you so much bob. I was going nuts trying to find that info.
I'm driving to pick it up tomorrow and I don't like driving 10 hours without having my ducks in a row. |
