-   -   Carb needle material? (https://www.offshoreonly.com/forums/general-q/296210-carb-needle-material.html)
THRILLSEEKER 05-12-2013 01:28 PM
I'm getting ready to order some spare needle/seats to keep in the tool bag. I see there are several options for needle material, steel, viton, SS, titanium, ect....
What is the best all around needle material for pump gas?
MILD THUNDER 05-12-2013 02:04 PM
Viton. This place has excellent prices. Ive had great luck buying all my carb parts from them.
http://www.allcarbs.com/detail.php?p...ctgn=38&stt=15
FIXX 05-12-2013 05:53 PM
Fixx
Holly? you will also need to know what the flow rate is..they come in differant sizes... .120 and up ..
THRILLSEEKER 05-12-2013 08:28 PM
Yes, Holley 4150 750CFM. There are'nt any numbers or markings that I can see stamped into the originals.
MILD THUNDER 05-12-2013 08:35 PM
The link I posted is the .110 Viton needle and seat. It comes standard in most holley carbs. 750, 800, 850, etc. Holley part #6-504
FIXX 05-12-2013 09:34 PM
fixx
mt 4779 4150 style had .120's in it..
MILD THUNDER 05-12-2013 10:10 PM
My holley master book shows the 110's for the 4779, 4780, 4781, etc. Even the 1050 and 1150 dom's. My 850's were used, and the ones I pulled out were stamped "h". Forgot what H stands for? but I replaced them all with ''.110'' when I was rebuilding them. The smaller 600,650 carbs call for .097 needles.
But, to get back on topic, you want "viton'' because they seal better, and a little more resisitant to dirt. Steel needles are for alky. With alcohol, generally you go larger with needle and seat size, than you would with gas. Putting a .150 needle in a typical 750 or 800 wont do anything. Unless your running a single carb application and making 1000HP or more. Hence why the single carb'ed blow thru stuff making over 1200hp requires dual needle and seat bowls. Saw that first hand on my buddies engine on the dyno. Sucked the bowls dry at 6000RPM. The best fuel pump in the world wasn't gonna fix that issue. Fixx knows that story
THRILLSEEKER 05-13-2013 08:29 AM
Thanks for all the help guys.
