-   -   Bravo 1 gear lube capacity. (https://www.offshoreonly.com/forums/general-q/296220-bravo-1-gear-lube-capacity.html)
buck183 05-12-2013 08:04 PM
Getting all my stuff together for my spring service. I guess old age is getting the better of me. Can't for the life of me remember how many quarts of gear lube I need to service a Bravo 1.
Thanks in advance....
Mbam 05-12-2013 08:40 PM
Here you go
http://www.mercruiserparts.com/tech/...ubeCharts.aspx
Smitty 05-12-2013 08:52 PM
Seriously ??? Alzheimers setting in already ????? :)
:lolhit:
buck183 05-12-2013 09:35 PM
:lolhit:
Believe it or not, I have a real long story that contributed to my confusion. Was too long to type out though. Remind me to tell you next time we talk.
Mbam, thank you for the link. It helped a lot.
Buck
Griff 05-13-2013 01:38 AM
7 qts for both drives will be plenty. You will probably only need 6qts depending on how much gets spilled.
BTW, the Quicksilver HP gear lube is exactly the same as the Merc HP gear lube with a different lable. Merc lable is about $18 and QS is $12 at Walmart.
Meshikinquah 05-13-2013 03:23 AM
Good info
Originally Posted by Mbam (Post 3924021)
low_psi 05-13-2013 11:54 AM
$18 a quart! Where are you buyng your drive oil?? I paid $11.99/qt for Mercury HP drive oil at my local marine supply store over the weekend
soldier4402 05-13-2013 12:27 PM
just over 3 for each drive. Sometimes guys claim they cant get it all out.
buck183 05-13-2013 09:25 PM
Thanks Griff. I'll look into that.
Buck
ThisIsLivin 05-14-2013 08:50 AM
Become a preferred Amsoil customer and you can get Extreme Gear for $11.95
