Exhaust Valve Guide Clearance
What should the exhaust valve guide clearance for BBC 502?
Valve guide I.D. - valve stem thikness = ? |
Normally aspirated or supercharged? Is this a stock 502 or something that will be leaned on?
Originally Posted by Budman II
(Post 3926098)
I am pretty sure the number I heard was .0017 - .0020 or thereabouts for a performance marine application. FWIW, AFR's site says their guide clearance generally runs .0013 - .0016, but they recommend checking with your engine builder for heavy nitrous usage, blower applications, or marine endurance applications.
(Post 3926234)
Originally Posted by Seahawk 2000
(Post 3926261)
Would that spec be different if there was no blower just N.A. carb?
I would advise talking to one of the pros on the board, particularly someone who does a lot of head work. Eddie Young, Bob Madera, Haxby, MER - all of these guys contribute regularly on OSO, and all of them are very willing to answer questions. I am not a pro engine builder so I cannot offer much in the way of specifics, only what I have gleaned talking to some of these guys. Nothing like getting the story from the horse's mouth, so they say. |
.0018
I set all of our marine heads at .002 on the exhaust guide clearance with 11/32 valves. If the guide is straight with no taper you will have no problems. We also run the blue viton seal on int and ex side. This clearance works on almost all applications the only time we alter from this is if we are going to run into very high egt's like on a turbo charged engine. Then we will run steel exhaust guides with bronze liners so the bronze guide will not chip and run threw the turbos. We check all the heads that come threw the shop even the new ones because 90% of the time they are on the tight side. Joe Irwin
Originally Posted by IRWIN
(Post 3926507)
Valve = 11/32" (.343) + .002 = .345. So the guide clearance is .345? |
What you do is measure the valve stem diameter if its .3410 then you make the guide .3430 which will give you .0020 clearance. Valve stem diameter varies from manufacturer so you have to measure the valve that your going to use. Joe Irwin
| All times are GMT -5. The time now is 03:11 PM. |
