Fountain K Plane Trim Solenoids
Local Merc dealer doesn't have the White Rogers K Plane solenoids that I need. They're pushing the Merc equivalent.
Current setup has solenoid grounding through base. Merc solenoid grounds through a terminal. I don't see any issue with modifying my harness connections. But... I've read just about every thread on every site about these solenoids, but I don't see any retrofit information - Any issues that I'm not seeing with this retrofit? Thanks. http://i16.photobucket.com/albums/b1...ps4d535fea.jpg |
Just run the grounding wire to the grounding terminal instead of the mounting bolt. Or go to AutoZone and pic up the same as you have for $10 if you prefer. Nothing special about these. Just a big ol relay.
That one kinda looks just like the Stinger ones I used on my stereo amps. Main difference is 3/4 terminal and if you need a constant or intermittent power solenoid. I'm assuming an intermittent is what required. |
| All times are GMT -5. The time now is 09:19 PM. |
