-   -   575sci.... Fresh water cooling...... Anyone ? (https://www.offshoreonly.com/forums/general-q/296652-575sci-fresh-water-cooling-anyone.html)
4bus 05-21-2013 08:53 PM
Originally Posted by Vinny P (Post 3929673)
I am very confident that the engines will continue to run at the same temps they do now. As long as the heat exchanger can dissipate the proper amount of heat, there will be no problems. Right now, the engines run about 150*.
Sounds like you have done your homework. When some one mentioned 185 degree temps earlier in this thread I was worried, those temps would destroy a 575 rather quickly.
Aluminum heads would be a great upgrade seeing that you are going closed. And would help with detonation issues should the temps increase.
Good luck and keep us posted with what you find and how it turns out
smiklos@sunprint 05-22-2013 06:04 AM
I was running 185 on a N/A 540 with afr heads. It probably would hold 150 F. I wanted temp.
Steve
smiklos@sunprint 05-22-2013 06:05 AM
Steve
Vinny P 05-22-2013 05:56 PM
Steve
Running at 185* is not a problem. No way you should run that hot with salt water in the engine. Even though I run strickly in salt water, my engine runs 180*. I can get away with it because I run closed cooling.
