Originally Posted by glen george
(Post 3932173)
Check the safety switch on the shifter? You could also run a hot wire to the dist and bypass the safety switch.
(Post 3932173)
As ive said a couple times, I'd look into the carb. But apparently the O.P. isn't interested in that. |
Originally Posted by MILD THUNDER
(Post 3932256)
Wouldn't a issue with the safety switch be present on the trailer when running? Most boats with transmissions use a neutral safety switch on the trans itself.
Originally Posted by Fountain Family
(Post 3932268)
I will look into the carb and appreciate the help very much. I am not able to get to the boat right now but when I do I will let you know what the screws are set at. I hope it is something as simple as that. Thanks again for your help.
Yes.but as mild thunder said look to the carbs first.lot cheaper.i still have 1 motor the rpm drop is greater than the other however i haven't had a chance to play with it with this wonderful weather we've been having here.
what kind of ignition system do you have? I had the same issue on my scarab years ago....turns out my MSD distributor had one broken spring inside it...ran fine when at idle...could rev it and everything....but would die as soon as it was put in gear....
Originally Posted by Wally
(Post 3932511)
Originally Posted by Payton
(Post 3932172)
How is your ignition timing?
(Post 3932649)
Timing is set to 34. Is that where it should be?
But I would definitely start with adjusting the carb, because the back fire "assuming the back fire is through the carb" indicates that it is running lean. Fix that and it will have the power to go into gear. |
What carb do you have on it now? A 850 has to be set up different than a dominator.
| All times are GMT -5. The time now is 11:53 AM. |
