Tach jumps all over
I have a pair of 500efi's and the livorsi tachs jump all over around 3000 rpm on both engines. Under 3000 they work fine. I just changed to brand new tachs as I thought they were the problem. The result was the same. Anyone have this problem before?
I'd check the grounds real good, and make sure the tach signal wires aren't getting interference from anything routed next to them.
Unfortunately anything more than replacing something electrical with an identical item is like chineese to me. I can do mechanical stuff no problem but electrical I suck at!
I had the exact same issues with a 358 Sonic.I had one tach fail and couldn't get the replacement to sit still over 3000 rpm. I went back and forth with Gaffrig and probably tried 4 or 5 different tachs before I finally got them to operate correctly. They were baffled too and sent me all different wiring configurations before we found the right ones. I'd call them and tell them the issue. They were great with my problem
Do you have factory plug wires? I know you didn't mention anything about doing any other work then the tachs but I've witnessed the exact thing you mention when a friend had a 500 efi and he ran the 8.8 wires instead of the factory merc wires. Maybe something with the resistance? It was the only thing he changed on the motors, put a brand new set of factory wires back on and tach was "normal" again. Not an expert opinion just my .0000002
Plug wires can do it.
It has moroso wires. Factory merc wires might help?
Originally Posted by ttuton
(Post 3932820)
I had the same problem on one of my 500 efi's it happened to be one of the wires on top of the coil that was defective. Crank the engine and jiggle wires on the coil and the distributor to see if there is a change in engine rpm or sound. It's definitely electrical problem though.
Poor connections.. Grounds, powers or signal. Any could be it. Your boat sits in the winter? Had same issue here in MI. Moisture.... Corrosion.
Just my thoughts. |
I had the exact same problem and never did get it corrected. I went as far as running a new signal wire by itself to the tach and running the tach off an independent battery, changed plug wires, running a separate wire from the distributor to the block to ground the distributor. This was several years ago and after trying multiple tachs from Gaffrig I just gave up. Whats funny is I have a digital tach mode on my gps speedo and it works fine. If you get them to work please post your solution.
I brought my boat to my marine mechanic and he checked all grounds and connections still the same problem. He also installed tach filters from livorsi and that didnt work either. He hooked up an old analog tach and that worked fine. We are both confused. I picked up the boat so I can use it for the weekend and then I will bring it back. Any other ideas?
Any fix yet on this? I have one motor doing the same thing checked all the grounds all good changed modules same problem. Maybe it's the wires?
Originally Posted by MrCIG
(Post 4109634)
Old threads with good info.
http://www.offshoreonly.com/forums/g...s-500-efi.html http://www.offshoreonly.com/forums/g...ng-around.html |
(Post 4109634)
If you guys would just stop revving the engine the tach will stop jumping....
NEXT! |
I had the same problem..Nordskog gauges.Merc thunderbolt IV ignition. I tried everything, ran a new wire, changed the tach, checked all grounds. Problem solved when I switched to MSD ignition complete with new distributor
The Cure
I had the fluctuating tech problem on my Formula 353 w/ twin HP500 EFI's. Went through all the troubleshooting stuff discussed here: swapped tachs, plug wires, checked grounds till sunrise, etc.. No joy until...
Turned out the problem was the ground connection between the distributor base and the block. The issue was caused by the paint job on the block which insulates it from the distributor base. The easy cure, suggested by to me by someone at Mercury Racing, is a jumper wire between the distributor cap hold-down screw and and engine-block ground. Worked like a charm. Its dead simple hook up a temporary jumper to validate that it solves the problem for you. This may also cure other guages jumping around as revs increase through the 2000-3500 rpm range. Note that the engine will operate flawlessly without the distributor-base grounded to the block. This grounding apparently serves to ground out electrical noise from the ignition appearing on the tach signal wire. |
(Post 4109634)
Post 19 is correct. Livorsi is also working on a fix that would go in-line on the tach signal wire. Hope fully we will have something in the next couple of months.
| All times are GMT -5. The time now is 10:57 PM. |
