carb jeting question
I have a question about my carb jeting on my engine setup,
engine is 468ci gen 6, 8:1 comp ratio, Edelbrock alum ported head, hyd roller camshaft, b&m 250 blower @ 5.5 - 6 boost, twin QFT 850 marine blower carb boost ref, run it at 5500-5600 rpm. With that to achive an AFR at 11 WOT and a AFR at 12 at 3000 rpm i need to jet the primary to #77 with 4.5 power valve and the secondary have jet #106 so does it have any problem to run them with a big diference between the pri and sec jet size? At 3500 rpm the power valve is open due to 0 vacuum and that rpm is my cruising speed and the AFR drop at 11, i know that is a rich mixture for cruising but i dont know what i can do to make the cruise speed leaner without afect the WOT AFR too much because i have already some big jet in the secondary. |
Any thought on that??
? do you have a powervalve in the secondary circuit?
Originally Posted by FIXX
(Post 3934379)
You should have some vacuum at 3500 rpm's.
Your power valve should open when you first open the throttle plates and you have no airflow yet. (No vacuum). Once cruising at 3500 you should have 10 inches or so, depending on the cam. |
Originally Posted by vintage chromoly
(Post 3934635)
| All times are GMT -5. The time now is 12:25 PM. |
