Torque spec for Gen VI oil filter adapter?
Anyone know the torque spec for the oil filter adapter that screws onto the filter pad for a Gen VI 454? Found this link that lists an oil filter adapter bolt at 18 ft lb and fitting at 49 ft lb, but not sure if that is it or not.
NATC - bolt torque specs, gen iv versus gen vi? Also, do I want to use some blue or red loctite on the adapter? Thanks! |
Here are some from the merc manual
Torque Specifications Oil Baffle Nuts 25 lbft 34 NVm Oil Filter Adapter Nuts 40 lbft 54 NVm Oil Pan Bolts (5/16-18) 80 lb in 9 NVm Oil Pan Drain Plug 15lbft 20 NVm Oil Pump 70 lbft 95 NVm Oil Pump Cover 80 lb in 9 NVm Remote Oil Connector (1/2 in. x 13) 25 lbft 34 NVm |
| All times are GMT -5. The time now is 01:43 AM. |
