Boat performance changes?!
The boat:
'99 Formula 330 SS Dual Merc 454 L29 engines (SN: 0L34xxxx) w/ about 400hrs/ea (stock AFAIK) Bravo 3 outdrives (2:1 ratio), rebuilt by the previous owner two years ago 26P props So last year I remember being able to hit about 4600RPM and getting about 45-48MPH @WOT on a good day; other day I could only hit roughly 4200RPM and about 40-42MPH @WOT. This year I seem to be limited to 4000RPM and 38-40MPH even on a good day?!?! Speeds are measured with my Raymarine E7D (GPS). Can anyone explain to me what all can cause problems like this? In all cases both engines performed almost exactly the same, telling me it's very unlikely to be:
Here are the things I checked/tried (with no change):
Here are some ideas I have for the culprit, although I'm still very much a noob at this so I could be wrong...
If you have any insight or experience with this kind of thing, PLEASE post. Edit: One other thing I forgot to mention - Even though the throttle is moving to the max position when I move the throttle control levers, they hit this 4000RPM wall at about 3/4 throttle - from there nothing changes as I go from 75% to 100% throttle. |
barnacels might be the problem,they can really cause a lot of drag,also btm paint will really slow you down.
Any growth on the bottom will slow you significantly. Before you do anything else haul the boat and clean the bottom.
Clean the bottom.
Clean bottom. I've seen this same question with answer on another boating site geared towards big fishing boats.
Clean the bottom. I had a Sea Ray 40 EC with twin 3208 400 horse diesels that with clean props and bottom ran 32 MPH. After 6 months in the water it wouldn't make 25...send a diver down and clean with a brush ($300) it ran 28~30.
The $hit that collects on the bottom kills your performance. As a side note...don't leave your Bravo 3's in the water ...you will be re-building them every 2 years if you do and you will eventually replace them. My partner has Volvo Duo props on his Sea ray Amber Jack and he just spent $7500 re building them after 2: years in the water....and the Volvo's are far superior to the Mercs. |
Originally Posted by sprink58
(Post 3938133)
The $hit that collects on the bottom kills your performance. As a side note...don't leave your Bravo 3's in the water ...you will be re-building them every 2 years if you do and you will eventually replace them. My partner has Volvo Duo props on his Sea ray Amber Jack and he just spent $7500 re building them after 2: years in the water....and the Volvo's are far superior to the Mercs. Also - the hull drag issue is a no brainer. There is a lot of surface area down there that you are trying to push through the water. Get it cleaned very thoroughly and you will regain much of your lost performance. Old gas from last year could be another issue. The Merc EFI systems have a knock sensor that will retard the ignition if it is detonating due to bad gas. Get some fresh gas in there and see if that helps. |
Originally Posted by Budman II
(Post 3938195)
Yep, Sprink is giving you some good advice. Lots of posts out on the internet about Bravo III's succumbing to galvanic corrosion when left in the water. For some reason they are much more prone to this than their Bravo I/II cousins.
. Merc added an extra zinc under the cavitation plate and a bullet zinc on the prop shaft in the early to mid 2000's to try to help with galvanic corrosion but they still do not fair well when left in the water. |
Originally Posted by Knot 4 Me
(Post 3938204)
Two stainless steel props sitting next to an aluminum case..
Merc added an extra zinc under the cavitation plate and a bullet zinc on the prop shaft in the early to mid 2000's to try to help with galvanic corrosion but they still do not fair well when left in the water. Either way, do not leave Bravo-3's in the water. Oh, and your problem is almost 100% bottom growth, as everyone stated. The smallest amount of slime will low you down. Barnacles are bad. Check your tabs as well. A small build-up on those will really slow you down. |
Yep, and my outdrives have all the protection above (dual pucks per drive and extra zincs). I would love to haul my boat out, but it would mean buying a new truck... Since I'm not in salt or even brackish water, I'm hoping this level of protection will buy me a few years.
You would also probably be surprised how much weight your boat has gained due to water absorption, if it is kept in the water all of the time(which it sounds like it is). The barrier coatings ( aka bottom paint) help to slow the absorption as well as retard growth (nothing grows well in contact with copper compounds). In general, gelcoat is not 100% waterproof. Some may still remember the Donzi "blister boat" from the very early 2000's on this website. That boat sat in the water all season for a couple of seasons/years and looked worse that someone with very severe chicken pox :eek: That boat developed blisters, but it can also just absorb into the materials without the blisters.
Originally Posted by bob_t
(Post 3938544)
Wasn't referring to wood rot. Just the fact that when they sit in the water for extended periods of time (years), they can gain weight from water being absorbed into the laminate. Sort of like the matress commercials you see on TV. Wasn't implying that your boat has rot, or is rotting, just another source of added weight that could slow it down over time (years). If it happened in one year's time, I doubt it is from gaining weight. Probably more of the growth stuff that the others were saying.
(Post 3938996)
You can google " water absorption in fiberglass" and read lots about it, if you are interested. In general the weaves and resins are not completely hydrophobic. The wood is hydrophillic, and uses that "humidity" to start rotting, over time ... and depending upon how good of a job the builder did, and what wood/treatment of the wood, it can be a really long time before it rots. A lot of builders don't go back and coat the id of the thru holes they bore for engine mounts, transom assembly bolts, the bolts for steering ram attachments, etc, and those can allow direct impingement to the wood and then the rot starts to spread like termites. The barrier coatings do a good job of blocking absorption, in addition to retarding growth for boats that continuously live in the water. Just trying to give some helpful information that may be useful, or may be not, for your question.
the slowdown occured in one year. the seller had bottom clean and shiny when you bought it. i'll bet the slowdown occured EVERY year until bottom was defouled. you say it isn't salt water. makes it harder to beach it and let the tide run out and scrub it. you can get a lot with a long handled brush from the surface. borrow a rowboat...
| All times are GMT -5. The time now is 05:35 PM. |
