-   -   replaced engine now Alternator wont charge (https://www.offshoreonly.com/forums/general-q/297815-replaced-engine-now-alternator-wont-charge.html)
01gsxrjt 06-08-2013 08:58 PM
ok I got a 1985 wellcraft elcalibur with a 548 bbc I just put the engine back in and the alternator wont charge. There are four wires going to the alternator black which looks to be a ground, orange which looks to be the out put. and a red and a purple which im guessing one is a field wire. does anyone have a wiring diagram for the charging system if so please share. Ive looked and looked and looked I dont see any thing I forgot to plug in.
01gsxrjt 06-08-2013 09:14 PM
or if anyone knows where the voltage regulator is?
01gsxrjt 06-08-2013 10:30 PM
ok im a little slow today. the voltage regulator is on the back of the alternator. its a motorola voltage regulator. if someone has a diagram for this thing.
blaquebaja 06-09-2013 02:34 PM
go this web site Starters, Alternators and more for Cars, Trucks, Tractors and ATVs they have marine alt with wiring diagram hope this help
blaquebaja 06-09-2013 02:38 PM
Black= ground
Orange= starter/battery
Purple= switch power 12 volts
Red= constant power
01gsxrjt 06-10-2013 09:28 PM
Thanks figured it out. just removed brushing and cleaned them and everything started worked Thanks for the reply
