| Reckless32 |
06-21-2013 08:19 AM |
There are two fuel pumps on the 496. One is the Boost pump and typically primary culprit on the starboard side behind the separator filter assembly, and then there's the main pump on the port side buried deep (you should hope to not have to change that one)....Depending upon the year, you should only have to remove the fuel separator filter and mount (two bolts) and lay it out of the way to get full access. Should be a spacer in there too to keep an eye on. The newer motors with a different separator assembly I "think" may have the pump built into the filter assembly? Not 100% sure about those editions. After that pretty simple and obvious disconnecting/reconnecting the lines AND the electrical connector. While you're in there good opportunity to look around for touchups or to tighten hose clamps etc.
Another indicator would be to hook up a fuel pressure gauge to the Shrader valve on the fuel rail up top and check for consistent fuel pressure. With no alarms you're most likely on the right path.
Another note on spark plug wires or dead coils....Should one of these happen you will most likely start seeing a lot of excess soot buildup on your transom from the misfiring or non-firing cylinder.
Good Luck!
