496 ho IAC problems what now?
changed it out still have the code on the scanner and 2 beeps every minute. rinda scanner has IAC test mode which gives me an error code, IAC has no communication with the ECM ? any ideas?
Probably a driver issue or hardware issue within the ECM. Call and talk to Dustin at Whipple. He can fix this; as it's somewhat common.
ecm
i was thinking a ecm issue, thought about swapping ecm from the other motor to see if the problem moves
took the ECM off the good motor, beep is gone, hope someone can fix it without getting a new ecm
Originally Posted by c2boatman
(Post 3941411)
Contact Dustin directly at the link just posted. He CAN fix it, and with overnighting both ways you can be back on the water by the weekend. |
thanks, will do
| All times are GMT -5. The time now is 03:52 AM. |
