-   -   Engine bogging after jumping waves (https://www.offshoreonly.com/forums/general-q/298018-engine-bogging-after-jumping-waves.html)
pantera232 06-11-2013 08:46 PM
My 454 runs perfect in flat water all the way up to full throttle... When I head out the inlet jumping large waves and the boat goes on a 45 degree angle, when I land the boat starts starving for fuel damn near turning off...any ideas thanks guys
vince1645 06-11-2013 09:06 PM
My fist guess would be to check the float level in the carb
jeff32 06-11-2013 09:38 PM
same comment!
mike tkach 06-11-2013 09:58 PM
the float bounces and causes a brief over rich condition,pretty common with holley carbs.
Griff 06-12-2013 01:01 AM
Had the same thing happen it my 28 Pantera with a 525SC. The high launch angle and pulling back on the throttle in the air would cause the bowls to overfill and flood the engine.
jeff32 06-12-2013 06:17 AM
so, we all know what's the problem, but is there a fix to this? lower the float?
pstorti 06-12-2013 07:35 AM
fuel injection
vintage chromoly 06-12-2013 07:43 AM
Make sure you have brass floats. The plastic/nylon ones are more "bouncy", so to speak.
Ted G 06-12-2013 07:20 PM
Some of the old school racers would epoxy a small block of foam or plastic in the bowl under the float, this keeps it from bouncing so far down, some swear by it.
Mbam 06-13-2013 05:36 AM
Keep the fuel pressure right at 5 lbs, you might need a regulator. Higher pressure makes it harder for the float to keep the valve closed.
Holley also makse an offroad needle/seat
https://www.holley.com/6-513.asp
NightHawk 06-13-2013 08:29 AM
If you have the stock Weber carb Eldebrock makes one that you can use also. It's spring loaded. Great for boating in the air.
So2fast5u 06-13-2013 09:30 AM
Umm just a little FYI you will never get a Holley to work right with a 45 degree angle. The front bowl will fill up then when your back level it only has one place to go, the engine. I would be more worried about braking the boat in half then a carb trouble. Fuel injection as mentioned is the only way u can get away with that much angle.....
pantera232 06-13-2013 08:02 PM
Thanks for help guys ill play with float level
