Gauges pegged?
Anyone know what would cause the temp gauge oil pressure gauge to peg to the right and the tach to stop working?
if it helps they are all 3 right in a row. All working fine for first 30 min of the outing. |
Might have lost a ground under the dash?
Is the ground "daisy chained"? Which would explain the 3 in a row.
Ground wire problem.
The ground is usually daisy-chained for gauges. Sounds like a classic grounding issue. Not hard to fix.
| All times are GMT -5. The time now is 09:34 PM. |
